Discussion topic: Sky Q doesn’t link to broadband
This message was authored by: Colin44
Sky Q will not connect to my broadband after the big outage on Tuesday night. WiFi is working fine.
I've unplugged everything and followed all the online instructions.
no joy!
Re: Sky Q doesn’t link to broadband
no joy!
Hi @Colin44
Have you carried out a Network reset on the Q box?
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router.
Avatar for Colin44
Hi
thanjs for your advice.
I get to the 'network' and there is no option to reset
@Colin44 wrote:
Hi
OK @Colin44
There still should be the options shown to connect to your Router
Avatar for Colin44
I have options to connect but it fails every time
