Discussion topic: Sky Q disconnected
This message was authored by: Cazzzza
Sky Q disconnected
Every day for the past week I have to rest my broadband and try to connect my Sky Q 2TB box and mini boxes.  Broadband has been checked and ok but now can't connect any of my Sky Q devices.  I have followed the onscreen instructions to the letter every time.
Re: Sky Q disconnected
Hi @Cazzzza
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
If you are on Sky Broadband with the new Sky Max router then you need to connect it as if it is a 3rd party router.
If you are on 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
