This discussion topic has been answered Discussion topic: Sky Q connection issues
Message posted on 21 Jun 2025 11:14 PM
My Mum's Sky Q cut off last night. Tried all the usual tricks. Switched off & on. Tried resetting everything. Bought a new remote today & paired it up to the box. Sky connection checks say WiFi, Broadband & Sky Q box are all in good working order but her Sky options are not coming on. Firestick works so ruled out problems with the TV. Sky can't send an engineer out for 2wks & AI chats were no help.
Message posted on 24 Jun 2025 12:33 PM
Decided to buy a new HDMI cable & replaced that last night & all up & running now. Sky back on & Mum back on Sky Sports & Tennis. Thanks for the suggestions because I'm clueless about these things.
Message posted on 21 Jun 2025 11:24 PM
Re: Sky Q connection issues
What does "Sky options are not coming on" mean?
Presumably you can see the output from the Q as you paired a new remote. Why did you buy a new remote by the way?
Message posted on 21 Jun 2025 11:27 PM
There is no Sky home page appearing on screen. Mum thought the remote was faulty as new batteries didn't solve the problem & decided to try a new one
Message posted on 22 Jun 2025 05:48 AM
Maybe box has totally failed. What do you see on screen?
Message posted on 22 Jun 2025 12:19 PM
Just a blank screen showing
Message posted on 22 Jun 2025 01:27 PM - last edited: 22 Jun 2025 01:28 PM
Hi @Elaine2604 Have you checked that the TV is on the correct HDMI port? Note, a TV power reboot cannot do any harm.
Message posted on 22 Jun 2025 02:06 PM
Yeah, we tried that too but it hasn't fixed the problem. Tried all the usual fixes again today but still a blank screen. Even though the Sky checks are saying "no issues" with the Sky Q box....there definitely is a problem.
Message posted on 22 Jun 2025 02:12 PM - last edited: 22 Jun 2025 02:12 PM
@Elaine2604 does the standby light change from amber to green when you press the on button on the remote or press the on button on the box (the standby light is part of the on button on the box)
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 22 Jun 2025 02:18 PM - last edited: 22 Jun 2025 02:20 PM
Hi @Elaine2604 I would make sure that the picture resolution hasn't changed. If you point the remote at the Sky Q box, and then key in the sequence Home 1 0 8 0 Home it will reset the box to 1080i.
Message posted on 22 Jun 2025 08:31 PM
The box is outputting a signal and showing the menu - just no TV, by the sound of it
Message posted on 22 Jun 2025 08:51 PM
No menu....just a blank screen. Had to book a Sky engineer through an automated service as it seems impossible to speak to anyone in person
Message posted on 22 Jun 2025 10:24 PM
@Elaine2604 wrote:No menu....just a blank screen. Had to book a Sky engineer through an automated service as it seems impossible to speak to anyone in person
But the remote pairing screen did come on?
Message posted on 22 Jun 2025 10:36 PM
No remote pairing screen....it's just a blank screen when trying to view the Sky channels.
Message posted on 22 Jun 2025 10:40 PM
@Elaine2604 wrote:No remote pairing screen....it's just a blank screen when trying to view the Sky channels.
How did you do this then?
"Bought a new remote today & paired it up to the box"
Is that possible without seeing what it's saying?
Message posted on 22 Jun 2025 10:47 PM
My partner followed the pairing instructions from the box & assumed that it had worked, this led him to believe that the Sky Q box is the problem
