Discussion topic: Sky Q connected to wrong network
This message was authored by: Deano59
I noticed rrcently that my internet connection to sky q kept dropping..
i used the network setup in the sky q menu and it has connected to someone elses sky internet. I am with Vodafone. Nothing else is connected to the sky internet, just the sky Q box.
How can i reconnect to my own internet?
Re: Sky Q connected to wrong network
Hi @Deano59
What you are seeing in the Network set up is the Sky SSID of the Q box's Sky Mesh.
This is not the network to which you are connected.
You could try reconnecting your Q box.
On 3rd party broadband and your router does not have a reset button, reboot it by disconnecting the power lead for 30 secs and then reconnecting.
On  3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
When it connects you may still see the Sky SSID in the settings but this is normal.
Avatar for Deano59
Thanks for the advice. What I am seeing and supposedly connected to is Nerwork name SKYCEFBA. Is this the SSID to which you are referring?
Wouldn't know the SSID name @Deano59 but it's most likely going to be the Q Box WiFi Mesh.
You can only connect to any Sky router by using WPS and to do this you need to press the WPS on a Sky router while your Q box WPS light is flashing.
