Discussion topic: Sky Q - cable issue somewhere - help!
Find out more
Message posted on 21 May 2024 06:04 PM
Re: Sky Q - cable issue somewhere - help!
@monkeydust2 wrote:
Is there anyway for me to text the coaxial connection between two wires is good or not?
Hi @monkeydust2
I suppose you could connect the two cables together at on end and then see if you have
Continuity the other end between the two central conductors.
You could also check whether there is any short circuit between the conductors and the F plug casings.
