Discussion topic: Sky Q, bulk program deletion from the harddrive
This message was authored by: davidgc
Daft question, once you have watch a program and you then delete it, after a while one goes into recording management, one can only delete it seems from the harddrive one program at a time, which is fun if one has for example just deleted 125 "four in a bed" programs, is there a quick way to do a bulk delete from the harddrive?
Re: Sky Q, bulk program deletion from the harddrive
hi @davidgc
No there is no bulk method of using Delete forever but it should not be needed.
Most people don't even realise this function exists as the housekeeping  will reuse space  by those deleted in the normal way
This message was authored by: Dave+Lorde
It's slightly confusing, but in Recordings->Management, the 'Deleted' option allows you to undelete or permanently delete accidentally deleted individual episodes.
To delete all episodes of a recording, go to the 'Disk Space' option, which shows the number of episodes and the disk space they occupy. Selecting a series here allows you to delete all the episodes with one click, freeing up that disk space.
Avatar for davidgc
Level 4 icon
I see if the delete files are overriden automatically now I have no problem, but I have just checked it's only when you go into manage, deleted, that used harddrive space decreases when you permanently remove the deleted files, I believe years back I did get a drive full warning as it was up around 96 - 98 % full.
hi @davidgc
tghe space should reduce when you delet recordings without going into Delet forever, although I think Delet Forever does  make a slight difference.
I record every F1 session in both UHD & HD  each week and just deleting all sessions reduces my disk space by around 10% or more & typically hover around 75% (I really should delete more as I will probably never get round to rewatching most)
Like nearly everyone, I don't use the delete forever & have had SKY Q since 2017  - although I have done for the odd test etc
I guess it might be more useful if you are very close to full with lots scheduled
The 'Disk Space' deletion option works fine for me. I have a lot of series recordings that I watch occasional episodes of, so I 'delete all' every so often after I've watched the ones I want to. The system manages how the freed-up disk space gets used.
This message was authored by: nolte
When you delete it and it goes into the'deleted' section, if you don't manually delete them, I have found (for me at least) on sly q, it is 2 months for the system to erase them automatically from the deleted section.
ROI sky Q Customer.
I think this all depends on the amount of space is free & when needed
Needless to say long UHD programmes (such as F1 races & associated sessions) use up more space thus mine probably stays around a 3-4 weeks during F1 season slightly less when races are only a week apart (as I mentioned my usage is approx 75% before the race weekend starts & I record F1 sessions in UHD & HD  in case I want to watch on a mini)
This message was authored by: Patricia741
  1. I am trying to delete recorded programs on my sky box...... I go to recordings and for 3 days now it is saying please wait, please can you help me....many thanks
This message was authored by: Me134
Have you tried putting it into standby and plugging the box out for 5 minutes?
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
