Discussion topic: Sky Q boxes not working
This message was authored by: Simon64cfc
Sky signal not coming through to my tv. Prime video Netflix all working. Nothing working on all sky channels
Re: Sky Q boxes not working
@Simon64cfc
No signal and no satellite signal issues are different .
A message displaying ”no signal” tends to be generated from your TV and normally means your TV’s not seeing the Sky box on the relevant HDMI input.
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
