Discussion topic: Sky Q box
Message posted on 03 Feb 2026 06:08 PM
Sky Q box
My Sky Q box freezes more than twice a day it starts on its own when paused and when it dose it won't rewind to where I paused it I've tried everything the bots are saying but getting know where i was told a new box was coming then sky cancelled it i am getting very frustrated because I can't speak to a human
Message posted on 03 Feb 2026 06:20 PM
Re: Sky Q box
Hi @Gary021258
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
Regarding your issue.
