Discussion topic: Sky Q box wont play through tv
Message posted on 27 Feb 2026 06:06 PM
I have just been upgraded to fast fibre broadband but cannot get my Sky Q to connect with my panasonic smart oled tv through my Sony amp
Message posted on 27 Feb 2026 06:12 PM
Re: Sky Q box wont play through tv
@Angel611 wrote:I have just been upgraded to fast fibre broadband but cannot get my Sky Q to connect with my panasonic smart oled tv through my Sony amp
The broadband will have no impact on your Q box sending a signal to your TV. You need to make sure you are using high speed HDMI cables of the same speed and specification and that your Sony amp is capable of full 4K passthrough if you are connecting the Q box to it.
Why not try connecting the Q box to the TV directly then using eARC to send the audio to the amp?
