Discussion topic: Sky Q box wont accept router password
This message was authored by: Cgt2
Message posted on 25 Feb 2025 11:30 AM
Hi. I'm using 3rd party wifi (with Three) All my devices connect to the router but the sky box won't accept the password. I have triple checked it's right but it keeps saying it isn't. My sky box was very slow so I did a software update which sorted the slow problem but since then the wifi won't connect with incorrect password prompt. Any ideas?
Find out more
Message posted on 25 Feb 2025 02:39 PM
Re: Sky Q box wont accept router password
Try restarting your Sky box and your router. If it still won't connect using the password, try using WPS to connect instead.
