Discussion topic: Sky Q box won’t work with my Samsung remote
Message posted on 19 Aug 2023 05:24 PM
Hi
im having issues where my Sky Q box won’t work with my Samsung remote! We have phone Samsung as we thought it was the TV but they are saying the issue is with the sky Q box! How do I get hold of Sky as I'm not finding anything to speak to them!!
Message posted on 19 Aug 2023 05:33 PM
Re: Sky Q box won’t work with my Samsung remote
@Kevnsue wrote:
Hi
Hi @Kevnsue
TV remotes will not control Sky Q boxes unless there are specific instructions in the TV settings to set the Samsung remote to control a Set top box.
Normal procedure is to Pair the Sky Q box remote to the TV to control Volume, Mute On/Off and input select.
Pair your Q remote to the TV as follows;
Try completly resetting your Bluetooth remote.
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
