Discussion topic: Sky Q box won’t switch on
Message posted on 18 Dec 2024 09:59 PM
topic: Sky Q box not working. Not turning on and blue Q fading in and out
Message posted on 18 Dec 2024 10:26 PM
Re: Sky Q box won’t switch on
Hi @Pilew26
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
