Discussion topic: Sky Q box turns off.
Message posted on 19 Apr 2025 11:54 AM
My Sky Q box keeps powering off from the mains (no power not on standby).
Have to reset the whole socket for it to come back on and now I have lost all my recordings and my Mini Box isn't working.
Message posted on 19 Apr 2025 12:49 PM
Re: Sky Q box turns off.
Hi @Sunna2
If you carried out a Factory reset or hard drive reset in the Q box hidden menu then you do lose all Recordings.
Only the first reset (Reset Settings) in the hidden menu will retain your recordings..
Regarding your mini box
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
