Discussion topic: Sky Q box turning off
Message posted on 16 Jun 2024 09:38 AM
Sky Q box turns off after forst 30 seconds on start up. Once running stays on.
Previously reported and went through whole software/hardware updates and checks etc. etc. but still have the problem. Unfortunately last discussion thread timed out!
Message posted on 16 Jun 2024 09:45 AM
Re: Sky Q box turning off
Hi @Jessica80
Have you tried a Reset Settings in the Q box hidden menu.
Message posted on 16 Jun 2024 12:48 PM
Thanks for taking the time to respond, but yes tried all that!
