Discussion topic: Sky Q box recordings are showing message 'software issues' and recordings are freezing and blanking
Message posted on 24 Nov 2023 05:36 PM
Sky Q box recordings are showing message 'software issues' and recordings are freezing and blanking out
Message posted on 24 Nov 2023 08:00 PM
Re: Sky Q box recordings are showing message 'software issues' and recordings are freezing and blank
Hi @PJ09
