Discussion topic: Sky Q box problems
This message was authored by: Dave377
Sky Q box problems
I am getting occasional satellite signal problems/picture break up when the weather is normal. Another problem is starting watching a film on Netflix causes buffering that freezes. Both are resolved by rebooting the Q box. I would like to speak to an engineer which seems impossible
Re: Sky Q box problems
@Dave377
If you’re seeing a “no satellite signal” message check that the connections from the Sky dish going into the back of your Sky Q box are still finger tight. Otherwise it’s very likely a dish misalignment or possibly a failing LNB (on the arm of the dish) so check the troubleshooting on this link
It’s worth noting that:
You won't get to speak to an 'engineer' as they're out on the road. To speak to an agent call Sky which will initially be automated which may try to send you here to the forum, offer you online help or offer to send you a text. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Avatar for Dave377
The advice was useful but I think that problem is with the Q box as it work fine for a few hours before losing the signal and is rectified by rebooting the Q box.
