Discussion topic: Sky Q box not working
Message posted on 01 Jul 2025 11:51 AM
Sky Q Box won't switch on
Message posted on 01 Jul 2025 11:52 AM
Re: Sky Q box not working
Sky box won't work
Message posted on 01 Jul 2025 12:07 PM
Hi @JohnG2905
Have you tried pressing the Standby button (Amber led) on the front of the Q box.
If this turns the Q box on
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair to TV.
Failing this
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 01 Jul 2025 12:12 PM
Yes tried all of this can you send engineer out please
Message posted on 01 Jul 2025 12:27 PM
Hi @JohnG2905
Afraid you are not contacting Sky directly here as this is a customer forum.
If you need to contact them you need to persevere by phone.
To contact Sky
Select Need more help
at the bottom of the following link and this will lead to a phone contact.
Ignore all automated messages and wait for an agent
https://www.sky.com/help/home
The link I posted should give you the solution.
