Discussion topic: Sky Q box not working and remote freezing
This message was authored by: StevieD2
My remote keeps stopping working then sky q box freezing, have done all the factory resets etc. - anyone have any ideas? Thanks
Re: Sky Q box not working and remote freezing
Hi @StevieD2
Avatar for StevieD2
I did this, but thank you.
