4
This discussion topic has been answered Discussion topic: Sky Q box not found
This message was authored by: JackMiller43
Sky Q box not found
Hi - Got multiroom - my sky mini box stopped working, reset it several times.  Rebooted main box twice and the router (non Sky but worked fine until now).  The main box works, i dont think my mini box is the cause because a laptop with Sky Go on also wont play recordings cos it cant see the main q box, the network is fine its just the sky q box doesnt want to talk to other items?  do i need to call sky?
Re: Sky Q box not found
Hi @JackMiller43
Reboot the mini as above.
You will be asked to press the WPS button on the main Q box (not the mini as the Network reset will start the mini WPS automatically.
Hi @JackMiller43
Avatar for JackMiller43
Level 0 icon
ignore me - working again thank god
Level 0 icon
thanks for your help - mcuh apprecoiated
This message was authored by: oldbaldric
I followed advice given to me for the same issue on a laptop, The advice was to uninstall Sky go, reboot, sky q box and router, re install sky go and lo and behold, it works now.
