4
This discussion topic has been answered Discussion topic: Sky Q box not accepting WiFi password
This message was authored by: SteveGBennett
I have reset router and sky q box as per instructions on here. This is sky broadband. The wps set up does not work. Setting up by ssid and password does not work. The broadband and password is working on every other device in the house. It is solely the sky q that will not connect. Also the minibox upstairs is down and a sky booster halfway up the property has no connection. I assume they need the main box to be connected.
Any ideas. I have prebooked an engineer visit just in case
Re: Sky Q box not accepting WiFi password
If you are on Sky Broadband then you need to use WPS @SteveGBennett
On Sky broadband hold the Reset on the back of the router until the power light flashes green (about 10 seconds). Don't unplug or switch off your router while it resets. The power light will go green when it's done.
On Sky Broadband you will be asked to press the WPS button on the Sky router. (Not on the Q box as the Network reset will start the main Q box WPS automatically). Make sure you press the WPS button on the Sky router and not the reset button.
Location of WPS button below.
WPS definitely does work as long as it's in range.
This message was authored by: JimH23
this worked a treat after trying all afternoon to connect with the password thanks for the help
This message was authored by: AndlersAsh
 Neither of those options works for me especially since I installed a Sky Wi-Fi Max (?) router. All other devices retain their connection except for my Sky Q.
solutions recommended by telephone support included upgrading firmware on the Q box, WPS, searching for the SSID, power reset. It's pretty poor when the one device having issues connecting to Sky broadband is the Sky Tv box
any last suggestions before I cancel?
