2
This discussion topic has been answered Discussion topic: Sky Q box no apps
This message was authored by: diykid
Sky Q box no apps
All my apps have gone on my q box
Avatar for diykid
Level 2 icon
This message was authored by: diykid Answer
Re: Sky Q box no apps
Hi Thank you for your message. I have tried that 48hours ago and still not got any apps. Sky back room are supposed to be sorting it. But now getting a bit frustrated. Have done the refresh apps procedure just, but nothing as yet. Thanks again.
Hi @diykid
Have you tried rebooting your Q box?
Failing this try refreshing the Apps in the Hidden menu.
Select Apps 
then highlight Refresh all Apps on this box.
You'll see a message that says, 'Your apps are being refreshed'. This will stay on screen until you press Dismiss to return to normal viewing
It’s recommended waiting at least 5 minutes before doing so.
Refresh Apps can take up to 24 hrs to complete .
Avatar for diykid
Level 2 icon
