Discussion topic: Sky Q box keeps turning off after 20 seconds
This message was authored by: Kev97
Everytime I turn my sky Q box on it turns itself off after 20 seconds. I then turn it back on and it's fine. I have tried updating the software and that has not changed it. Any ideas?
Re: Sky Q box keeps turning off after 20 seconds
Hi @Kev97
Avatar for Kev97
I have tried this, it has not worked
Probably best to contact Sky for an Engineer to check your box @Kev97
Avatar for Kev97
Thanks for the help. I do think I've sorted it now. I don't know why but it appeared that my Samsung TV was causing the issue. I have now connected the TV to my WiFi and the issue has been resolved. Hope this might help someone else to encounters the same issue.
