Discussion topic: Sky Q box keeps rebooting
Message posted on 18 Nov 2023 11:27 AM
Sky Q box is rebooting nearly every night, just had software upgrade from sky
Message posted on 18 Nov 2023 11:35 AM
Re: Sky Q box keeps rebooting
Hi @Sambow57
Message posted on 18 Nov 2023 11:39 AM
Thanks so much, I'll give that a try
Message posted on 21 Apr 2024 03:27 AM
Doesn't work already tryed it don't bother
