Discussion topic: Sky Q box keeps having technical fault
Message posted on 25 Sep 2026 02:01 PM
I had an issue like this before, when I try and watch sky sports it tells me there is a technical fault and won't play anything. Then it will come back. I was put through to an advisor before and they said to come back here if I experienced the same issue again as by the time I spoke to them last time everything was working again.
Message posted on 25 Sep 2026 02:20 PM
Re: Sky Q box keeps having technical fault
Try the troubleshooting on this link which should be relevant for Glass, Stream and Sky Q...
https://www.sky.com/help/articles/there-is-a-technical-fault-with-this-channel
Message posted on 25 Sep 2026 02:28 PM
Thanks it happens frequently, I don't really think the answer to wait 5-10 mins and try again is acceptable especially when I'm trying to watch live sport.
I tried the troubleshoot but pressing 0,0,1 in setting didnt do anything so I went for a restart instead.
If it works, I suspect it will just be temporary and it will come back at a later point
Message posted on 25 Sep 2026 02:31 PM
Don't shoot the messenger. The Community, is predominantly made up of Sky customers helping other Sky customers. You aren’t talking to Sky by posting here.
Message posted on 25 Sep 2026 02:35 PM
I understand that, I'm just stating the case as at some point I'd hope someone from sky would pick this up as I was told to come back here and mention it again so an advisor could check.
