Discussion topic: Sky Q box keeps disconnecting for EE Broadband Router
Message posted on 27 Mar 2025 02:15 PM
We have recently switched broadband from Sky to EE as they were offering a better deal, however, since switching our Sky Q box keeps disconnecting itself from the router and we have to enter the password again. It then reconnects and works fine but after a day or so the same issue occurs and I have to enter the password in again.
No error message is displayed other than to say theres no internet connection and that it will keep trying to connect but unless I go into the settings and put the password in it never self remedies. Everything else works fine with the broadband so I don't think its an issue with the actual router.
I have seen a few threads on here with the same issue but I can't seem to see one where anyone has found a solution 😕
Message posted on 28 Mar 2025 11:20 AM
Re: Sky Q box keeps disconnecting for EE Broadband Router
Message posted on 11 Apr 2025 07:57 PM
Put the Sky Q box in standby.
Go into the EE Broadband Router admin mode and select 'Restart'. Give it a while to return to service.
Turn on the Sky Q box and check the status.
In the router admin mode check devices and confirm the router reports the Sky Q device is ok. It should be on a 2.4Ghz channel.
If not, reset the connection via the Sky Q box menu and connect again.
Connecting your Sky Q box to a non-Sky broadband router | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 23 Mar 2026 04:44 PM
I am having the same issue and can't speak to anyone about it, and the chat bot is not able to signpost me to anyone who can help
Message posted on 29 Jun 2026 06:48 PM
I'm having the same issue and it's driving me to despair!
Message posted on 29 Jun 2026 08:09 PM
@abercrombie10 wrote:We have recently switched broadband from Sky to EE as they were offering a better deal, however, since switching our Sky Q box keeps disconnecting itself from the router and we have to enter the password again. It then reconnects and works fine but after a day or so the same issue occurs and I have to enter the password in again.
This used to happen to me. Its a longstanding issue. Its to do with the unified 2.4G - 5G SSID. The Sky Q box can't cope with it. The absolute bulletproof fix on an EE hub is to create a secondary Wifi Network or set up the guest network on the router and make it 2.4g only.
