Discussion topic: Sky Q box is unresponsive to remote control and reboot.
Message posted on 10 Jan 2025 01:10 PM
My Sky Q box is unresponsive to the remote, is not connecting to wifi or responding to manual commands. Rebooting wifi, pressing reset and disconnecting the Q box don't work. No lights are showing
I can turn on the TV screen with the remote, but no response when pressing the Sky button.
Help please!
Message posted on 10 Jan 2025 01:29 PM - last edited: 10 Jan 2025 01:30 PM
Re: Sky Q box is unresponsive to remote control and reboot.
Help please!
Hi @Olive4
First reboot your Q box.
If your remote does not function,
Message posted on 10 Jan 2025 03:07 PM
Thank you for your replies, unfortunately neither work. There is no sign of life in the Q box, no amber or green lights and no response to the standby button.
Message posted on 10 Jan 2025 04:08 PM - last edited: 10 Jan 2025 04:10 PM
Hi @Olive4
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the power supply is included if the replacement Q box has the orange coded multi pin din socket in the back of the Q box. See below.
Message posted on 11 Jan 2025 04:47 PM
Many thanks for your help, that's it sorted now
