Discussion topic: Sky Q box has stopped working
Message posted on 07 May 2024 06:24 PM
Was working this morning came back from playgroup and no power, have disconnected everything and still does not work
Message posted on 07 May 2024 06:28 PM
Re: Sky Q box has stopped working
Hi @tony0684
https://www.sky.com/help/articles/sky-q-box-wont-turn-on
Also if the box you are replacing is a 2TB there are two versions of power supply. One has a standard C7 (figure of eight) power lead socket in the back of the Q box. The other has a separate power supply. Although this still has the C7 power lead into the power supply there is a multi pin Din power socket in the Q box for connecting the power supply. Make sure that the replacement box has the power supply included if the Q box has the orange coded multi pin din socket in the back of the Q box. See below.
