Discussion topic: Sky Q box has a constant flashing q
Message posted on 04 Mar 2023 10:09 AM
When we try to turn on the sky q box the q constantly flashes and even if we turn it off and on again this doesn't work. We've not had the box very long
Message posted on 04 Mar 2023 10:41 AM
Re: Sky Q box has a constant flashing q
Assume nothing is playing from your recordings?
