Discussion topic: Sky Q box does not start
Message posted on 28 Mar 2025 04:33 PM
Sky Q box fails to start unless the power is disconnected and reconnected keeps this fault every day for the last week now.
Message posted on 28 Mar 2025 04:34 PM
Re: Sky Q box does not start
Hi @angry100
