Discussion topic: Sky Q box - blackscreen using apps
Message posted on 09 May 2025 09:05 AM
I'm probably the nth person to report this problem but my Sky Q box regularly freezes, with black screen, when watching iPlayer or Disney+
I run a small ISP so I'm confident my broadband and Wi-Fi are not the issue. Netfilx and Prime work fine, it's just iPlayer and Disney. We rarely get issues with regular Sky TV, apart from losing audi-video synch from time to time, which is fixed with a reset. I'm assuming it's just a poor quality unit, I know other people suffer similar issues. Other than the usual 'fixes' does anyone have ideas to remedy. Many thanks.
Message posted on 09 May 2025 01:09 PM
Re: Sky Q box - blackscreen using apps
Don't know what you mean by usual fixes @Brettski+S
Have you tried a Reset Settings in the Q box hidden menu.
Message posted on 12 May 2025 03:45 PM
Many thanks, I'll give this a try.
by 'usual fixes' I mean powering off the Sky Q box, checking my network settings and broadband provider.
Are you aware of Resetting Settings having a positive effect on this phenonema? I believe it's a common problem with the Q box.
Thanks again,
Brettski
