Discussion topic: Sky Q biox
Message posted on 24 Apr 2026 11:11 AM
Sky Q biox
I have problems with 2nd room sky box. Recording flicker for seconds then start but if I rewind plays properly
watching a recording I get throw out back to TV and have to then reaccess
couldnt get on to red button to select a football match
Message posted on 24 Apr 2026 12:03 PM
Re: Sky Q biox
Hi @Suse22
Reboot the mini as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you have the new Sky Max router then you need to connect the WPS to the main Q box.
