Discussion topic: Sky Q apps not working
This message was authored by: CAA2
Hello,
The problem I have is that almost all the apps on my Sky Q will not work. (Prime, Netflix, Sky Sports+, iPlayer etc. ) They will start but after a short while they will display various error codes - in other words they will not connect. Oddly, YouTube works fine.
I've tried the usual stuff, restarting the box and router. Also refreshing the apps from that secret menu.
All these apps work fine on other devices - phones, tablets and TVs.
Has anyone any idea what this issue could be?
Thank you.
Re: Sky Q apps not working
@CAA2 wrote:
Hello,
Thank you.
Hi @CAA2
Avatar for CAA2
Thanks for your reply, however the steps didn't make a difference. I can download episodes of shows fine but almost no off the apps will work. Very strange. Does anyone have any other ideas what could be causing this?
Thank you.
This message was authored by: ozsat
Could be a poor wifi signal or interference by the SkyQ box.
Downloads will work as they will download even if the wifi is poor - they just take longer.
But is a stream needs a certain amount then you may see problems.
There is a speed test on the netflix app which will tell you the speed your SkyQ is receiving.
Thank you.
SkyQ Silver bundle (V2 2TB with UHD/HDR + two minis) in Sky region #71 (Oxford) using VirginMedia Gig1 Fibre (1.2Gbps/100Mbps).
