5
This discussion topic has been answered Discussion topic: Sky Q and connectivity issues
This message was authored by: Stfcnas
Hi, just replaced a faulty Sky q box and now it won't connect to my router and none of the mini boxes connect. Have followed every combination of resets / restarts and still nothing. Q box does connect to my Deco mesh
Avatar for Stfcnas
Level 2 icon
This message was authored by: Stfcnas Answer
Re: Sky Q and connectivity issues
Update issue resolved using the below
Can Sky Q work with Deco?
Can Sky Q box work with Deco?
  • The Sky Q box can work with Deco and it’s recommended to build a wired Sky Q network among Sky Q boxes and Deco for more stable performance.
When Sky Q box and Sky Q mini box are connected wirelessly, their own Wi-Fi may be causing interference to the router's Wi-Fi network and stream video easily takes up most of the bandwidth, which would cause slow or unstable problem in the network.
The wired connection is faster and more stable than a wireless connection, wire the Sky Q box to the router, and wiring the Sky Q mini box to the Sky Q box will make the network more stable and perform better thus we suggest building a wired Sky Q network.
If you want to learn more about Sky Q box and Deco, please refer to:
https://community.tp-link.com/en/home/stories/detail/1886
What can I do if Sky Q can’t work with Deco? Problem Phenomenon:
We have encountered issues such as the Sky Q box and Sky Q Mini box freezing when connecting to Deco, Deco or the connected devices have unstable or slow speed problems when the Sky Q box is connected, etc.
Suggestion:
1. Update the firmware of the Sky Q box to the latest
2. Disable Sky Q’s 2.4G and 5G Network and build a wired Sky Q network
It is highly recommended that you disable the 2.4G and 5G wireless networks on all Sky Q box and Sky Q Mini boxes and instead use a wired connection to connect each Sky Q box to Deco units. A typical Sky Q wired deployment is shown in the diagram.
3. Change the Wi-Fi channel used by Sky Q
For Sky Q boxes (Main and Mini) that cannot use a wired connection and can only keep the wireless network on, it is recommended to switch the 5G channel used by the Sky Q box from the default 80MHz/ch.36 to either 40MHz/ch.36 or 40MHz/ch.44. Both of these options are worth a try.
Following these adjustments, execute the Network Optimization function within the Deco app to align the Deco system with an optimal channel.
4. Turn off the Sky Q Wi-Fi Hotspots
Turn off the Sky Q Wi-Fi Hotspots for all the Sky Q and Sky Q Mini boxes as per Turn off Sky Q Wi-Fi hotspots | Sky Help | Sky.com
5. Contact TP-Link Technical Support
If your problem persists, please contact TP-Link Technical Support with the following information:
1) What Sky Q devices are you using in total? Have you used any other devices besides Sky Q box and Sky Q Mini box such as Sky Q Hub?
2) Network diagrams (as shown in previous pictures, describing how Deco units are connected and how Deco units are connected to the Sky Q devices).
3) Screenshots of the network settings on each Sky Q box.
Is this faq useful?
Yes No, I need more help
Problem Phenomenon:
Suggestion:
Is this faq useful?
Hi @Stfcnas
Do you have the possibility to connect all of your Q boxes by Ethernet to your Deco mesh discs?
Avatar for Stfcnas
Level 2 icon
Hi, unfortunately not
Why would you connect it to your router and not the presumably better wifi network of the mesh?
Avatar for Stfcnas
Level 2 icon
I've tried to connect to the second deco mesh tower but then seem then lose internet connection to main Sky Q box.
Getting a little frustrating to say thr least 😤.
Also nigh on impossible to get q to find the router also.
Managed at one point to sonehow get connection in both mini boxes upstairs but then got the "technical issue wirh this channel" error.
Avatar for Stfcnas
Level 2 icon
Suggestion:
Is this faq useful?
Problem Phenomenon:
Suggestion:
Is this faq useful?
