2
This discussion topic has been answered Discussion topic: Sky Q & Paramount Plus issues
This message was authored by: JulianW1
I have signed up to Paramount+ on my Sky Q box, I can sign in okay but when I go to watch something I just get the loading circle and never loads the program or film. Can someone help me fix this problem so I can actually watch something on paramount plus. Thank you!
This message was authored by: Mark_Jabez Answer
Re: Sky Q & Paramount Plus issues
Hi @JulianW1 .
The only fix to this is
Press Home
Scrole down to settings
Highlight Settings - Press 0,0,1 then select(to go to the Hidden menu)
then Scrole down to apps
the Click on Refresh Apps.
Hi @JulianW1 .
Press Home
Avatar for JulianW1
Thanks for getting back to me, we will try that and hopefully 🤞. Thanks for your help.
