Discussion topic: Sky Q Wifi Disable
This message was authored by: Charlie+64
Sky Q Wifi Disable
Is there a way to stop sky q box from turning off wifi around 3am
I have turned off eco mode but it still happens
The box is connected by ethernet cable, so thought if I go into the settings and turn off wifi it would be ok, the box is fine but other devices don't have a wifi connection. It's like they connect via the sky q box and not the router. All the router lights remain green.
Thanks in advance
