Discussion topic: Sky Q - TV constantly crashes
Message posted on 25 Jan 2026 09:42 PM
Message posted on 25 Jan 2026 09:48 PM
Re: Sky Q - TV constantly crashes
@Aa2952 wrote:
My TV constantly crashes. I'll be watching YouTube, Netflix etc and when I try pressing home the TV does not respond. Top left corner is black ( no picture and sound) and its stuck on the TV guide. My remote is also unresponsive.
Hi @Aa2952
To re pair the remote press 1 & 3 together on the remote and follow onscreen instructions to re pair. Q box must be on with green led.
