Discussion topic: Sky Q Recorded Programs Drop Out when Playing them
Message posted on 20 Nov 2025 06:58 PM
Having recorded shows on Sky Q, when I watch them at a later date, they frequently just stop playing and drop back to the active Sky channel. I then have to restart the show playing again, albeit from where it stopped. This is becoming very frustrating!
Message posted on 20 Nov 2025 07:26 PM
Re: Sky Q Recorded Programs Drop Out when Playing them
Hi @Malvern
