Discussion topic: Sky Q Mini
This message was authored by: Laura84uk
Sky Q Mini
I've just set up the Sky Q mini box. Is it right that it doesn't seem to work when my main Sky Q box is on standby? Does this mean I have to have both TVs running at the same time to watch the TV with the mini box?
Also, none of the apps I have installed on my sky Q box seem to show on the mini. The main purpose of having a mini for this second TV was because I understood it would mean I could run apps such as netflix on it, without the need for having a Smart TV. Is this not the case?
Many thanks
Re: Sky Q Mini
Hi @Laura84uk   Mini boxes work when the Main box is in Standby. I would start by checking that the new Mini box has its Software up to date. It should be Q250.
Home -> Settings -> System info -> Software version -> Setup.
All Apps should be available on the Mini box.
