Discussion topic: Sky Q Mini setup
This message was authored by: Jonno730
Sky Q Mini setup
Hi, I am trying to setup Sky Q Mini in our gym which is a distance from our router. Is there a range it needs to be in to link to it. Can it link to my main Sky Q box which is only about 15 foot away? Thanks, Jon
Re: Sky Q Mini setup
@Jonno730 yes it will link to your main Q box by wifi when you ate sertting it up it will ask you to press the WPS button on the nearest piece of Q equipment so goto the main box and press the WPS button on that
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Avatar for Jonno730
I have tried that with no luck.
It cannot seem to see it.
