4
This discussion topic has been answered Discussion topic: Sky Q Mini homepage stuck
This message was authored by: Bernie+Carraroe
I cannot connect to Sky on the mini box (main working fine). Have reset, switched off numerous times. Just stuck on this Home Screen, but cannot select any options. Remote is working, volume, on/off etc.
Only two cables plugged into box, the pink hdmi connecting to TV and the blue ended power. Should there be a wireless mini connector?
Re: Sky Q Mini homepage stuck
Hi @Bernie+Carraroe
The two cables are all that is needed. WiFi is built into all Q boxes.
Might be worth  completly resetting your Bluetooth remote.
First make sure that the Home button on the remote is not stuck.
If all seems OK
Then make sure that you are pointing your remote at the Q box and press 1 & 3 together until the led flashes and follow onscreen instructions to re- pair.
Avatar for Bernie+Carraroe
Hi @Bernie+Carraroe
If all seems OK
@oldfella @Thank you sooooo much!! I have been two days trying to resolve this issue! Greatly appreciated.
This message was authored by: Nic5566
Resetting the remote worked! No need to set it up for volume etc mini box was stuck on homescreen after several reboots, arrows wouldn't move, this fixed it
