Discussion topic: Sky Q Mini TP Link Deco Issues
Message posted on 05 Feb 2026 10:22 PM
Hello,
I’ve recently set up a TP-Link Deco mesh system for our Wi-Fi, and after a couple of days I noticed that our Sky Q Mini box has been intermittently losing its wireless internet connection. After doing some Googling, I found that others have experienced similar issues, but I couldn’t find any clear solutions.
I’d prefer not to use an Ethernet cable between the Deco and the Sky Q Mini as that wouldn’t be convenient, so I’m hoping to avoid that if possible. The only temporary fix I’ve found so far is turning off both the Deco Wi-Fi (at the wall) and the Sky Q box, then turning them back on again.
Any help appreciated!
Message posted on 06 Feb 2026 08:11 AM
Re: Sky Q Mini TP Link Deco Issues
@Calum17 Sky Q minis can only connect by WiFi to devices that support Sky Q's wifi mesh therefore you cannot get a stable connection to your Deco WiFi. If you want to use WiFi use wps and connect to your main Sky Q box. Sky can supply boosters if the mini wont connect properly. Alternatively use an Ethernet connection to the Deco.
Message posted on 06 Feb 2026 07:09 PM - last edited: 06 Feb 2026 07:16 PM
The mini has to talk direct to the Q. It is not using the deco mesh. Yes it's ridiculous.
Message posted on 09 Feb 2026 08:09 PM
Thanks for your reply. Just so I understand properly, what do you mean by a main Q box, is that our Sky broadband Hub?
Do you know how I would go about identifying a 3rd party router that supports Sky Q's wifi mesh?
Message posted on 09 Feb 2026 08:20 PM
@Calum17 the main Q box would normally be the bigger Q box that most people would have in their living room that the sayelitte cables attach too
No third party router would support the Sky Q mesh only the Sky Q hub or Broadband hub routers support the Q mesh
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 09 Feb 2026 08:27 PM
And only the older black Sky routers. The modern white ones do not.
Message posted on 09 Feb 2026 08:28 PM
Well thats a shame! Thanks though... I don't know if its just our property or what but we don't have satelittes/antenna cables for our sky set up. We just got a Q mini and the hub.
Message posted on 09 Feb 2026 08:30 PM - last edited: 09 Feb 2026 08:30 PM
And sky boosters can also form part of that mesh.
I was wrong when I said they have to connect direct to the Q because you're on Sky broadband. In that case they can connect to the router and but still not, I don't think, via a mesh.
On a 3rd party ISP they can't even connect via the router, it has to be direct.
Message posted on 09 Feb 2026 08:32 PM
@Calum17 wrote:Well thats a shame! Thanks though... I don't know if its just our property or what but we don't have satelittes/antenna cables for our sky set up. We just got a Q mini and the hub.
Yoy don't have Sky Q then. You have Stream.
I can turn the 5ghz off on the Deco and see if that helps at all but it looks like I'll need to return it as its caused more problems than solved sadly.
Message posted on 09 Feb 2026 08:35 PM
I think you're right, I'm assuming this doesn't change anything?
Message posted on 09 Feb 2026 08:58 PM - last edited: 09 Feb 2026 09:00 PM
@Calum17 wrote:I think you're right, I'm assuming this doesn't change anything?
Yes, its networking is completely different from Q. It should work fine with the Deco afaik, but maybe ask in the Stream forum.
Message posted on 10 Feb 2026 09:00 AM
I have a Deco XE75 pro mesh system connected to the white sky router and have no issues with the main Q box connecting to the mini.
Sky Q 2TB (V3). 2 x Mini. LG G3 65inch. LG S95 QR 9.1.5 Soundbar. Sky Full Fibre Gigafast Broadband.
Message posted on 10 Feb 2026 09:26 AM
Will do, thanks again.
Message posted on 10 Feb 2026 09:31 AM
I have the black Sky router however, I have set the Deco up to be its own router. Its not plugged into my Sky router, its wired direcetly into my ONT.
