Discussion topic: Sky Q Mini Frozen (constant green led)
This message was authored by: RogHe
I have three Sky Q Mini's which are all connected via wired network cables and have wifi disabled.
1. Master Bedroom
2. Kitchen
3. Office
2 of the Sky Q Mini's (2 & 3) get frozen with the green led on, no signal to the TV and no response to the remote or front panel buttons. The only way to recover them is to power cycle them with a 10 second off time. They will then go through the long winded started up process (Hello etc) and will operated fine. They Mini's seem to freeze if they are not turned off via the remote (The TV gets turned off but not the Mini).
The other Mini (1 an older unit) does not suffer this issue.
I have tried all of the Sky problem solving procedures and also searched on here for further help but the problem remains. It seems to be a fundamental hardware issue possibly only with the newer units?
Unit 2 has been replaced but the problem remains.
A Sky "Engineer" has visited but he was extremely cocky and unhelpful.
Has anyone else experineced this issue?
This message was authored by: Daniel-F
Re: Sky Q Mini Frozen (constant green led)
Posted by a Sky employee
Hi @RogHe
I’ve escalated your post to Sky and the Messaging Team may get in touch with you later.
Look out for a blue/red speech bubble at the bottom of your forum page. You’ll then have 48 hours to click on it and join the private chat or it will close automatically. If you fail to respond to each chat reply within 48 hours the chat will again close down automatically even if your issue hasn’t been resolved. Replies from Sky aren’t instant so you’ll just need to check the chat thread regularly.
This link explains the Community Messaging process.
Daniel
Community Moderator
This message was authored by: Addie15
Hi there! Thank you for escalating this. We have sent an invite to RogHe.
