Discussion topic: Sky Q Mini Box Network Connection
This message was authored by: whiteclosegate
One of our mini boxes loses network connection multiple times during the day. Tried connecting via WiFi and cat 5 cable but the issue still persists.
Watching TV and this happens, screen freezes, menu sometimes comes on with small screen in top left saying network connection is stopping viewing. Some times it comes back on by itself, other times need to power cycle the mini box. Main sky q box in living room is fine when this happens, so not sure if it's the mini box itself or the network connection between the two...
Really frustrating on a daily basis
Re: Sky Q Mini Box Network Connection
Hi @whiteclosegate
Reboot the minis as above.
If you are on Sky Broadband and the Router is nearer to the mini than the main box then you can try pressing WPS on the router instead of the main Q box. If you do this make sure you press the Sky router WPS button and not the router reset button. If you get the first mini connected then for other minis use WPS on the nearest Q device (main Q box or Sky Router if on Sky Broadband or previously connected mini).
This message was authored by: Tdm.I
We have had the same issue.  We changed our router to sky max as supposed to be better, it made it worse.  An engineer came out they replaced mini box and bought a booster with her.  She was not confident in the situation being resolved.  Yesterday the box was freezing again and very slow.  I spoke to sky and today I received a new pod that boosts the signal.  It is better but still not 100%.  Apparently I may need another pod as all my walls internally are brick built so the signal needs to improved.
You may have the same issue but I couldn't see what router you had.  The new white max one is causing lots of issues for people and Apparently a broadband engineer should come out not a tv engineer.
