2
This discussion topic has been answered Discussion topic: Sky Q Internet
This message was authored by: SharkyW
Sky Q Internet
Ok, I'm confused. I am experiencing picture breakup problems with Sky Q apps. Sky and Live channels OK so not likely to be Dish or LNB.
By default, Skq Q uses WI-FI for programs, so maybe signal quality. Settings say OK
Re-configured Sky Q to use Ethernet rather than WI-FI. Restarted box.
Still getting picture problems on various apps so could be the cable. Unplugged the Ethernet cable from the back og the Sky Q box. OK, the program is still playing. Disconnect the two LNBs and the program is still playing! So it looks as if the Sky Q is using WI-FI even though it is not configured to do so.
Checked the cable with a tester and it shows OK.
 Next step is to disable the WI-FI on the router
Can anybody explain what is going on or am I starring in an episode of the Matrix.
Re: Sky Q Internet
https://helpforum.sky.com/t5/Sky-Q/Sky-Q-Apps-pixelating/td-p/4692163
Re: Sky Q Internet
Avatar for SharkyW
Re: Sky Q Internet
Thank you for the information. I can see that I'm not the only one suffering with this. It's just another nail in the Sky coffin.
Just for information, I have discovered that there is a delay between unplugging the Ethernet cable and the app video signal dying. So in my case the Ethernet is definitely live.
