Discussion topic: Sky Q Internet Disconnect
This message was authored by: Greaveshipowa
Anybody else still suffering this inconvenience. One discussion suggested it's the box. Will sky send out a new box, as my Internet is not the problem !
Re: Sky Q Internet Disconnect
Hi @Greaveshipowa
Do You have the new Sky Max (white) fibre router?
Avatar for Greaveshipowa
No, I'm on Virgin Broadband . 1gb
Hi @Greaveshipowa
Don't unplug or switch off your router while it resets. The power light will go green when it's done.
Highlight Status and then select Reset on the right hand side. Follow instructions to connect by WiFi to your router. Even if reset is not listed there is still an option to connect by WiFi to Sky or 3rd party router.
On 3rd party (non Sky ) broadband then you need to enter the SSID and password for the router 2.4 Ghz WiFi band.
Hi Old fella,  I am connected to the  sky Q box using ethernet ! I'll try your suggestion  to see if it holds. Thanks
Shall I switch of the 5ghz on the Q box !
You cannot beat an Ethernet connection @Greaveshipowa
If you have no mini boxes on WiFi,   when the main Q box is connected by Ethernet you can turn off its WiFi to make the Ethernet connection more stable
