Discussion topic: Sky Q Hard Drive Error
Message posted on 10 May 2026 05:38 PM
My Sky Q keeps freezing and showing a hard drive error. Frequent turning on and off the power for 30 seconds isn't fixing the problem. Also, seeing a connection error occasionally when the router is fine.
Message posted on 10 May 2026 05:45 PM - last edited: 10 May 2026 05:46 PM
Re: Sky Q Hard Drive Error
Try following this link. It should lead to a replacement box if needed
https://www.sky.com/help/articles/sky-q-hard-drive-errors
If you do need a new box remember to remove the viewing card from the faulty box before it disappears into the back of the couriers van and accept any new power cable DPD deliver with the replacement box in case it's different to the one you have.
Message posted on 12 May 2026 12:21 PM
Thank you. This was very useful. I've ordered a new SkyQ box. Just waiting for a date.
Could I ask if the courier is able to assist with taking the card out of the box and disconnecting. I am elderly and have amputated hand so would find this physically very difficult.
thank you
Message posted on 12 May 2026 12:27 PM
Unlikely I'm afraid. They are on a tight schedule. They will be expecting the box to be disconnected and by the front door with the card removed. They then leave the replacement box in its place (they don't set it up).
Perhaps ask a family member, friend or neighbour to assist you.
Message posted on 12 May 2026 12:29 PM
Thank you that's helpful. I haven't easily got someone to help me I'm afraid.
Message posted on 12 May 2026 12:30 PM
Unfortunately if the box isn't ready to swap the courier won't leave the replacement.
Message posted on 12 May 2026 12:31 PM
Thanks for advice.
