Discussion topic: Sky Q Box issues
This message was authored by: Morna1
Sky Q Box issues
My Sky Q box regularly drops of the Internet because my broadband is not with sky so I have to put in my password everytime. Now it has started  saying endure the correct viewing card is inserted. We have not changed or moved the viewing card. I have now taken it out to clean and put back in the correct way. Still have the sane issue. Is my Sky Q box broken ?
Re: Sky Q Box issues
Hi @Morna1
First
Once the Q box is back up and fully running if you have the same issue.
Check your viewing card is correctly inserted. Viewing card is in the right hand end of the box.
If it is in correctly there is not enough of it sticking out to grip and remove it.
Push it fully in and it will pop out slightly enough so you can remove it.
Make sure that it is in chip side up and chip end in first. Push it gently fully in and you should feel a slight click when it is engaged. If it has popped out enough to remove it is not located correctly.
If you are satisfied that it is in correctly
Try refreshing your Viewing card.
Home - Settings - System info.
Highlight Viewing card number and then select Setup on the right hand side.
Then select Use this option to trigger a callback
No call is actually made but the Viewing card should be refreshed.
