Discussion topic: Sky Q Box Not Working
Message posted on 29 Dec 2023 07:21 PM
Sky Q Box just keeps saying Waiting for TV Schedule when I click on TV Guide what does this mean have restarted box and still saying the same. Have internet connection to.
Message posted on 29 Dec 2023 07:35 PM
Re: Sky Q Box Not Working
Hi @Jenny15
Message posted on 29 Dec 2023 08:08 PM
Thank you I just done this and now it's saying no hard disk. There is a problem with your hard disk drive. I've tried resetting that to and no luck.
Message posted on 29 Dec 2023 08:12 PM
Hi @Jenny15
If you have been through the following link and cannot solve your issue then you need a new Q box
https://www.sky.com/help/articles/sky-q-hard-disk-error-messages
