Discussion topic: Sky Q Apps
Message posted on 21 Jan 2026 06:16 PM
Sky Q Apps
Having issues opening Apps on Sky Q I.e BBC iplayer , Prime , Netflix etc
Message posted on 21 Jan 2026 06:31 PM
Re: Sky Q Apps
@Peter35 what happens when you try
do you get any error messages ?
LG 49SJ 810 V UHD TV
Google Pixel 10 Pro XL mobile
Message posted on 21 Jan 2026 06:34 PM
Re: Sky Q Apps
Hi my friend ,no error messages I just get a blank black screen , yet I can open the Apps on my tablet or phone
Message posted on 21 Jan 2026 06:57 PM
Re: Sky Q Apps
@Peter35 Have you tried rebooting your main Q box ie
if that doesn't work
you could try refreshing the apps in the engineers menu
To enter the engineers menu do the follow
press the home button then scroll down to setting and hi-light
do not press select/enter but press 001 then select this takes you into the engineers menu
scroll down to apps > refresh
