Discussion topic: Sky Prime & Netflix slow
Message posted on 26 Aug 2026 09:31 PM
Prime and Netflix slow via Sky remote on Samsun 58 in TV
they take iowards of 30 seconds to start up
once up - all is generally ok
some times the wheel whirls to load more of the progtam
if i use the Samsung remote the Prime and Netflix starts in 1-3 secends
I think the issue is related with two mac addresses
2.4Gz - ends in 52.3e
and
5.0 Gz - ends in 52.3b
a tweak from sky's router end would fix things i believe
our sky q box ( 2 tb ) has been swapped three four times already and have to restart the box unplugging it from the mains - holding the on off button in - rhis resets it )
it takes over 15 mins to reset Q bix and run updates
any help gratefully received
Message posted on 27 Aug 2026 07:45 AM
Re: Sky Prime & Netflix slow
and
Hi @Ns14sky Try rebooting your router by removing the power cable for 30 sec then reconnect to reboot, then reboot your main SKYQ box by turning the power off at the socket for 30 sec then turn back on?
